I'm looking to get a field monitor, like a "8, 9" or maybe 13"
but I must say that I have no experience with them.
What do I look for and also, what is blue check? In layman's terms
please.
sony is a good bet.. blue gun button only fires the blue so you can calibrate the monitor. I would also suggest getting one with 16x9 and more importantly a underscan button as you can only see partial picture on the DVX viewfinder.
I have a JVC TM-H1375SU 13" monitor. I am very pleased with it. It can do 16:9, but has no blue check. It does allow you to calibrate it through a special menu though. I use it both with my edit suite and in the field. But for field use, I'd probably go with a 9" next time. Size, weight and a top handle are important.
Yep, 750 lines of resolution. That was one of my criterias when looking for a reference monitor. I keeped flinching when I saw monitors at 350 or 400 lines. I am sure if you shop around, you'll find good deals.
$700 for a Sony PVM 20" monitor is a very good price, but for field use it's way too big :-/. I heard from a Sony reseller that the PVM series (not the BVM) tubes are actually consumer TV tubes. You might want to verify that info, as I'm not sure if it's 100% true.
I have a Sony PVM-8045Q and it is wonderful. I find the 450 lines to be adequate, and even an advantage, if your project will be seen on standard televisions.
It has all the features that Zoom suggests getting.
Hence the need for a good ref monitor on s-video, and a standard TV on composite. Having both extremes really help narrow down lots of problems.
But we're getting side tracked here. ftroop wants a field monitor, and 20", although very attractive size and price wise, is pretty cumbersome. As for the number of TV lines, it really doesn't matter how many there are on a field monitor, regardless if it's a 8", 9" 13", or 20".
[quote author=Flintstone link=board=Links;num=1067226698;start=0#7 date=10/28/03 at 18:53:46]Hence the need for a good ref monitor on s-video, and a standard TV on composite. Having both extremes really help narrow down lots of problems.
But we're getting side tracked here. ftroop wants a field monitor, and 20", although very attractive size and price wise, is pretty cumbersome. As for the number of TV lines, it really doesn't matter how many there are on a field monitor, regardless if it's a 8", 9" 13", or 20".[/quote]
What about LCD monitors like Panasonic's TC-7WMS1? How much quality or reliability can you get from them? They are certainly lighter and drain less than a CRT monitor.
