There's no "perfect mic", a lot of people prefer the NTG-1 over the NTG-2 or 3, the 897 over the 875, VideoMic over whatever, they're all different and opinions are like...you know.
http://www.dvxuser.com/V6/showthread.php?t=27879 <----Great place to start.
Pic a mic that sounds the best to you and go with it. Chances are no one other than you will hear a difference in the end result.
The Audio Technica AT-875R is the best cheap mic on the market. I have one, use it all of the time and am very happy with the sound, size and the cost was less than $200.00. I recorded samples with it here http://www.kenstone.net/fcp_homepage/right_mic_brockett.html
Dan
I have not tested the NTG-2 but I did test the NTG-3 and it is one of the best values on the market. It sounds like a better version of the Sennheiser 416 for a lot less money.
AT-897 does nothing for me. It is not a bad mic, but I feel that the 875R is more practical (it is designed as an
Dan
The NTG-1/2 are very good budget mics. The complaints come mostly from people going straight into an H4n which doesn't seem to have enough gain in some situations. (And, frankly, a lot of people buying budget-level mics have absolutely no idea how to use them.)
Can the NTG 2 go straight into a 550D, 60D, 5D? I know it's not the best way to go but slating and post syncing isn't the most efficient strategy for me either.
The camera audio isn't the best I know, but the HD picture quality, portability, stealth nature and low daily cost of a DSLR can't be beat, even with it's major audio deficiencies. I just need to find a shotgun to plug into the camera when I work alone which is more all the time. My Sony lav has plenty of gain and seems to match the camera quite well.
If I have shoot where audio is critical I use a Sony EX3 and all the audio gear and crew come with it.
If you have to compromise on something, it is better to deliver inferior pictures with pristine audio
No, of course it doesn't. But if you have a limited budget you can't buy everything you might want and so you have to make a decision ... do I spend the money I do have on getting a better pictures or on getting better audio. If you have $1500 to spend, which will help you deliver the better program ... a $500 lens and a $1000 audio setup or a $1000 lens and a $500 audio setup? I would suggest the former is the preferred deployment of limited resources.I've been in advertising a long time, and I agree completely with your position on the message, but to suggest that delivering an inferior picture has anything to do with achieving better audio is misguided advice.
A preamp such as the Juiced is going to be useful with ANY DLSR you use, until you get to the point in your work that a full-blown mixer is the better option. Even then, I own a Sound Devices 442 mixer but I still also have a 4-channel Juicedlink in my kit, just in case. No matter what mic you have, unless it's a consumer mic like the Rode Videomic with an unbalanced miniplug output, if you need to take a balanced mono XLR mic into an unbalanced stereo minijack input, you need a proper adapter and an active adapter like the Juiced does the best job of that. A Juicedlink that provides phantom power opens up a whole additional range of mic options for you and would be an appropriate choice to work with both your current camera and any new one you get no matter where your camera upgrade path takes you (unless you're upgrading to a full-blown professional video camera with balanced XLR line-level inputs.)I don't want to add more additional preamp hardware because this camera is very temporary, a few months more at best, and the next camera may require something different.
$110 a day?!?!?!?!? Where!?
