ryan brown
lOwEr CaSe Member
EDIT: PROBLEM SOLVED. It was only that one scene that keeps falling out of sync. I believe it was initially imported and stamped by final cut pro with the wrong settings. I went into audio/video settings, sequence settings, matched it to default to my current project, started a new project and clips now sync. Except for that one scene, but I believe I need to get the original audio again off another hard drive. Here's where I found info on the matter: http://library.creativecow.net/lyon_matt/fixing-fcp-assets/2 It may be that, or maybe there was just issue's with the audio recording from that one scene. I won't know until I get the original audio back, but either way, I'm back to work. Thanks for the help
So im just starting the edit on a feature and im tearing my hair out with the audio. Footage was shot on red epic at 24, sound guy recorded wav files at 48.0KHz with microsoft PCM format. Ive converted audio 10 times and cant figure it out. Ive used 'switch', quicktime and itunes to convert from wav file to aiff at 16bit, 48KHz and it falls out of sync (audio runs fast). Ive tried trashing fcp prefs with no avail. Ive also taken the original files and synced them in quicktime pro itself, and it even falls out of sync in quicktime with the original wavs, and converted aiffs. HELP. I havent been editing much the past couple of years, so i may just be overlooking something simple.
