I have a dvd which i've produced/edited and on playback there is a buzz if the volume on the tv is cranked and it is paused,, i've even exported just the video file from my project and it still makes a rather unpleasant buzzing sound when the volume is turned up.
I color graded and adjusted the levels to the 0-100 IRE specs using a NTSC monitor. I also applied a broadcast filter on top of the entire sequence and set it at 100IRE max for luminance value to ensure there would be no issues with the white levels. I checked the vectorscope for possible over saturation that would cause interference with the audio signal....is there anything else that would be causing this? Maybe i'm reading the vectorscope wrong but all of the footage has the buzz, everything on the dvd which i exported and encoded buzzes on my tv. Is this an encoding error? A levels error? It's chaos I tell ya, but isn't it always?
cheers,
p.
cheers,
p.
