Hi,
I am new to external batteries, having used internal batteries before.
My camera accepts between 7.2-15v of external power.
Looking at v-mount options and most output around 14.8V of nominal voltage. Some are rated at 16V of maximum voltage even though the output is 14.8V.
How concerned should I be if my camera only accepts 15V and these batteries output 14.8V nominal but 16V maximum voltage?
This is an old camera so I have to be particular with the battery I do choose.
For example:
"Power your camera or other pro video equipment with the IDX CUE-D95 91Wh Li-Ion V-Mount Battery. The battery can supply up to 16.8 VDC to the plate, and can also provide up to 50W to power accessories through the integrated D-tap output. CUE-D batteries feature a nominal voltage of 14.8 VDC and a maximum output voltage of 16.8 VDC "
BTW I don't have a v-mount plate. I was expecting to go straight from the battery via d-tap to the camera.
Many thanks.
For example:
Many thanks.
