I'm attempting to play back a video that is encoded with DVCPRO HD. This is a file that was exported from AE CS3 on an Intel G5, running Leopard 10.5.5, and QT Pro Version 7.5.5.
I am trying to run the file through Compressor on a different machine to compress it into a smaller format for distribution, but the file will not play back in Finder or in FCP. I am able to play back the file on a computer other than the one it was created and exported on.
The machine I'm using for compression is a PowerPC G5, running Leopard 10.5.5, QT Pro 7.5.5, FCP 6.0.4, and has all the latest updates installed. I did some research and discovered that DVCPRO HD is a codec that Panasonic licenses to FCP. I checked and the codec is installed in QT under HDD/Library/Quicktime and for FCP under HDD/Library/Application Support/Final Cut Pro System Support/Custom Settings.
Any ideas?
Any ideas?
