No Bulbs?.
As I am doing my searches for a light kit, I am noticing a lot of places asking a lot of money for these kits but they do not come with bulbs! How much does a bulb cost? I am sure the higher the wattage the more its going to cost but why don't they include them in with the lights?
Re: No Bulbs?.
Here's an example of some bulbs. http://www.bulbman.com/index.asp?PageAction=PRODSEARCH&txtSearch=FEL&btnSearch=GO&Page=1
You can find most anything you need at bulbman.com. The example above is for 1k FEL lamps which are about $16. each and are used in a lot of fresnel lamps. Bulbs will cost you between $15 to $20 each depending on what size and wattage you have. 2k's are more expensive, but if you can find the bulb code on the fixture you are buying, you can get prices from bulbman.com
