Yann Gourhant
Hi,
I'm a bit used to the AIs but I've never used any AF lens. I'm interested in the 17-35 f2.8 and maybe the 80-200 f2.8.
I was going to buy one used. But when I turned the iris ring, nothing happened. The diaphragm stayed wide open. There's a small lever on the mount, but when I pressed it, nothing happened either. Is this a flaw, or are they supposed to work like this? I didn't buy it, but I thought I'll ask you. I may have to test it mounted on the adapter, right?
edit: is there a problem using the push/pull model? If you could afford the difference, would you go for the ring model? Or would you go for a better prime or two?
