While I shoot most of my commercial and corporate work on several Canon L series lenses because they are quick and easy, I have a set of vintage Nikkor AI-S primes that I use for more narrative and creative work (35 f/1.4, 50 f/1.4, and 85 f/2.0).
For the most part, I like them. I prefer to achieve a more "vintage" look over "super sharp and clinical". However, there are a few things that I don't like about them.
1) they can be too short. I can't put a large filter on the front at the same time as a follow focus, as they bump into each other. A longer lense wouldn't have this problem, although being light weight can be nice sometimes.
2) the 35mm blooms so much wide open, it's basically unusable. Although I have used this as a quick "beauty filter" for a glowing ethereal look. Not sure if this is common for all 35 f/1.4 or just mine is defective.
3) some of the wider focal length lenses aren't as fast as some other modern cheap options.
I'm currently looking to add both a wider (probably 20mm) and a longer (probably 135mm) lens to my set. So basically, I have two questions: First what other possible vintage lens options could or should I be looking at? Ideally they would be in a similar price range, but I've had them for long enough that I wouldn't mind "upgrading" if I felt it was worth it. Don't want to go over $1000 per lens, and $500 range would keep me happy.
Or, should I just suck it up and buy the modern Rokinon Cine lenses that are so popular. They are bigger, faster at wide focal lengths, and as far as I know, probably don't have the same flaws that some of the older lenses have (like my 35mm blooming wide open). They are also in the same price range.
