alexdias
This is way more complex than I can describe, but here it goes.
FCP sequence (90 minutes) and 6 tracks of audio for the 5.1 Surround mix.
Best way after several tests and a lot of researching:
Export individual audio tracks with correct labeling. Use surround set up on Compressor and create a single AC-3 file.
Export video only (ProRes HQ) and drop on Encore timeline. Match the AC-3 track (sync should be easy since they are exactly the same size).
Run the encoding on the Video track, Encore allow that, and burn to Blu-ray.
Results so far: out of sync, audio way too low, image is perfect and beautiful.
