Night Forrest Scene; Finding alternative to M18
ItsameMario
Hi All!
I just want to clarify because Image 80s are fairly new to me, The wattage source output for these are between 1680W to 1920W?
I'm trying to create an equivalent of an M18 (or more). Would this do the job? Thanks!
THe only access I'll have is edison (plenty of Amps so it's not a problem) and I need to keep the cost low. Suggestions? I'm doing a night forrest scene
Thank you!
Image 80 is 8x75W bulbs so it draws about 600W...
Not only that but T12 bulbs aren't the most efficient. So this wouldn't be close to an M18, unless maybe you're comparing to an M18 through full grid or bounced?
Image80s aren't nearly as versatile lights since you can't easily bounce or spot them, wide flood beam only, but convenient if you need a broad soft source.
