Merry Christmas from Sony
http://www.sonycreativesoftware.com/download/updates/vegaspro
Notable fixes/changes in version 11.0 (Build 510/511)
Mike
- Updated Sony AVC format render template customization to support AVCHD 2.0.
- Added StreamChase® feature for editing media while it is being ingested by an XDCAM® Professional Media Station.
- Added Sony Tablet presets to Sony AVC format.
- Improved performance for MVC reading.
- Added support for 24p MVC as well as support for additional 3D cameras (such as the Panasonic Z10000).
- Re-enabled support for “Mono (multiple)” templates for AIFF and Wave formats.
- Add the ability to create folders in Compositors window.
- Added Titles & Text Scroll Left preset for creating text crawls.
- Extended Titles & Text animation from first line to all lines for built-in presets.
- Added GPU acceleration for Pan/Crop rotation as well as Track Motion rotation, shadow, and glow.
- Added GPU acceleration for all track compositing modes.
- Added GPU acceleration to the Swap, Push, Slide, Squeeze, Spiral, Zoom, Barn Door, and Split transitions.
- Added GPU acceleration to the Invert effect.
- Added GPU acceleration to the Checkerboard generator.
- Improved GPU-accelerated image quality for downscaled images.
- Implemented some performance improvements in ProType Titler and Titles & Text generators.
- The cursor now stops at the exact end of a recorded event when recording is paused (for example, when using the Enter key).
- Upload to YouTube has been updated according to the YouTube specification: commas (not spaces) are used to delimit tags, and single-character tags are not allowed.
- Projects burned to Blu-ray Disc from the timelines now show elapsed time on hardware players.
- Fixed a crash that could occur when creating transitions using NumPad * or -.
- Fixed a crash that could occur when using audio plug-ins protected with PACE iLok system.
- Fixed a crash that could occur when rendering to ATRAC Advanced Lossless format.
- Fixed a crash that could occur when exiting the application after playing back time stretching on audio events.
- Fixed a crash that could occur when opening certain unsupported MXF files.
- Fixed an issue with Burn Timeline to Blu-ray Disc that caused an invalid Blu-ray image to be created when using the MainConcept MPEG-2 video format.
- Fixed an image glitch that could occur with GPU-accelerated MainConcept AVC rendering.
- Fixed an issue with GPU accelerated Sony AVC rendering using AMD Catalyst 11.10 or 11.11.
- Fixed an issue reading MPEG-2 files with non-Latin characters in the file name or path.
- Fixed an issue displaying certain non-Latin characters in ProType Titler and Titles & Text.
- Fixed issues when using nonsquare pixel aspect projects with some video plug-ins.
- Fixed an that prevented double-clicking an OFX pop-up fader from setting the correct default value.
- Fixed an issue where transitions would not appear on the Transition shortcut menu.
- Fixed an issue with Chroma Keyer changing colors when used in 32-bit floating point mode without GPU acceleration.
- Fixed an issue with Pixelate producing incorrect output when used without GPU acceleration.
- Fixed issues with Color Curves and Levels when used with images containing transparent alpha channels.
- NVIDIA drivers prior to R270 are not allowed for GPU-accelerated video processing as they can cause crashes.
- Fixed Paste Event Attributes to also paste OFX keyframes.
- Fixed an issue that could cause events to use the wrong media in certain circumstances (seen when project is later loaded).
- Fixed scroll wheel support for devices with high-resolution scroll wheels.
- Fixed an issue that prevented mouse clicks from selecting the active multicamera take when external monitor full-screen view was enabled.
- Fixed duplicate devices that could be displayed in Device Explorer.
- Fixed issues with External Controls not being detected when added and MIDI learning in Control Configure not working.
- Fixed an issue with closing audio ports when Close audio and MIDI ports when not the active application was enabled in Preferences > General.
Mike
