New tripod needed for crane which one?
Sky321
Hello
Please do not delete this topic i have searched and seen no one asking the same question as mine if you have a link please provide it
Hello
Just found this forum seems a great place with many good people to offer some advice
I have the Sony FX1 and want to get the 8 foot Kessler crane but will later upgrade it to the 12 foot so it will need to support the 12ft crane can anyone tell me what tripod i will need to use with this camera and crane
People have talked of so many heads and tripods I have no idea which one to choose
Will i need a 75mm half bowl or 100mm
I saw one tripod that could handle a maximum weight of 20KG would this be any good for the crane fx1 and all the counter weights
Thank you for your help and time
Weight is definitely an issue with the 12ft Kessler, camera, and counterweights. I went as far as making a DIY tilt/swivel in place of the regular pan/tilt head. The cheapest Bogen head that would handle the weight is around $1500.00. One of these days, I'll post my DIY "head" in the DIY section.
What system holds 20kg? It must be expensive.
Hello
Thank you for the reply
There are the 350MVB, 350SHMVB, and the 351MVB they all have a max load of 20KG
And you could add the 316, 526 head which are both rated at 16KG
That’s about the best i could find but i still have no idea how well this would work for the 12ft with a 2KG camera plus the weights
Just curious, but since you bought the Kessler and are intending to upgrade to the 12' extension, why didn't you go with their Mark 3 Crane Support Tripod? At $599 it looks like good value and is specifically built for their cranes.
Hello
Because i am in the UK and shipping something like that plus import fees would be very costly
mdslammer said:
I have the 12' Kessler Crane and use the Bogen/Manfrotto 528XB. It works just fine and will support up to 66lbs.
The sticks weigh almost 17lbs themselves and are built very sturdy.
Yes, by far , this tripod is the one I'd recommend for the money. It's only rated for 66lbs but I've had my 300lb jibs on them. A lot of the European crane companies also use them for their big cranes.
I have the 12 ft Kessler. Was gonna buy the 528xb sticks. It's a little early and can't remember what I use. It's the mid grade Manfrotto sticks. 3 somethings.
Anyway, I called Eric directly and he gave me a complete breakdown of weight capacities. Also, you may end up just going with the 528 because they're coming out with a 16 ft extension also. Call Eric Kessler, he's cool.
If you go up to the search button and enter "kessler tripod" you will find over a dozen threads offering advice and possible solutions.
Chris
Thanks for the help guys
keynstring
WOW they are coming out with the 16ft is that going to be $200 like the 12ft upgrade
yes i might go with the 528xb as it sounds like it will be good enough to take the16ft if i choose to upgrade
What head do you think i should get as there are so many to choose from
CMessineo
I have not seen anyone ask about the FX1 and this crane each camera has its own weight and the fx1 is 2KG alone
so i was not sure what tripod i needed
