NEW - RMS1010 Digital radiomic. system from Audio Limited
John Willett
  • Black anodised cases machined from solid high grade aluminium.
  • High definition OLED displays.
  • 100MHz switching bandwidth – more than enough to deliver flexibility while maximising battery use.
  • An unrivalled 2mS end-to-end delay!
  • And up to 20 systems can operate together in one TV channel.
The DX receiver. True diversity and true versatility.
A true diversity receiver with analogue and AES digital outputs that’s SuperSlot™ compatible and features full encryption.
And an OLED display which pivots so that it can still be seen when the unit is lying flat or is in a bag.
Compact digital transmitter with built-in SD card.
The TX transmitter uses two AA batteries housed in an all-metal, hinged lockable compartment. It has switchable output power. And a built-in SD card reader which can be used to update the system’s firmware.
Menu driven set up. Monitoring by app.
Both transmitter and receiver have maximum clarity OLED menu driven select and click displays that make set-up and operation very simple. Brightness can be reduced or the screens can be turned off entirely (as can all the LEDs). And there’s a free downloadable app which will control the main functions on the transmitter from a phone or iPad and monitor battery levels.
Info, with more pictures, HERE
Nice to see that Audio Limited is starting making digital radio mic systems !
Missing the size of the miniTX transmitter though.
Wondering now how it compares to Zaxcom's...
