adolgin
DVXuser Sponsor
Last few days I was playing with the idea of powering a monitor like BT-LH80W using common Panasonic/DVXuser style batteries, or common Sony, or Canon 7.2V batteries. The obvious benefit would be to use the same battery as used to power the camera, not Anton Bauer or IDX. These batteries are 7.2V, while the monitor needs 12-16V. Connecting 2 of them solves the voltage problem, and also extends the run time. I used our own TC200 charger body to build the prototype, http://dolgin.net/VDoubler.htm it has 3 AB studs added, and a XLR4 cable which would plug in into the monitor XLR to power the monitor. The "VDoubler" as I call it, would mount on the AB plate on the back of the monitor. It needs 2 batteries to run. The whole thing is about 2lb including the batteries, which is about the same weight as one AB Dionic 90 battery. Run time, using DVXuser or similar batteries will be 4-6 hours on one full charge.
This adapter as described will be probably around $100.
We do not own the BT-LH80W monitor, so there is no way to actually plug it in, and test the thing here. First, does anybody see himself using an adapter like this? It can be used with other monitors besides the BT-LH80W, as long as there is a DC input available, XLR or DC jack. Second, we are in Boston, MA. Anybody in the area who might be interested to try it out? We can also send it via UPS if no local volunteers raise their hands...
