New macbook pro dock with thunderbolt; byte-dock
That is the ugliest thing I have ever seen!
It is the antithesis of every design principle by which Apple has succeeded in transforming the world.
No self-respecting Mac owner would be seen dead with that abomination!
The Henge Dock is not that great. I own one and use it with my MacBookPro 17 inch. While I agree it looks better, I am tempted to get this to see if it works better. I tightened the allen screw to hold the display port cable in and it snapped the plastic on the henge dock. I DID NOT use a lot of force. Plus, I HATE the cable management. Or I should say, lack there of. Also, disengaging the laptop is a pain, and if the Henge Dock lifts up, the cables fall out of the bottom. AT LEAST they could have put a snap in cover on the bottom.
So, I care about functionality more than looks, so this might be better.
I'm guessing you don't get out much.
Personally I think the "design" of Apple is a nice addition to solid products, but I mostly use Apple products because of what they do & not how they look. If Apple made ugly products that worked just as well, but sold them for 25% less, I'd probably purchase the cheaper ones.
This doesn't look pretty, but if I needed something like this I'd consider it.
Think the Macbook Pro's would cook doing any serious business with the lid closed.
I have a MBP from 2007 that I've used about 70% of the time with the lid closed as a "desktop" computer. Thing is still working pretty well. There have been a few times that the fan is really going & I've opened up the screen, but I'm not sure of how much difference it made.
One thing I think has really helped is keeping the laptop raised & on an angle so that there is good airflow underneath & the heat can rise up & away from the machine.
The Henge dock doesn't mention anything about Thunderbolt passthrough, either.
It all depends on if you have a cable that passes all the thunderbolt signals. I have a displayport to DVI adapter hanging in there now, but nothing locks you in to what hangs out of that whole, provided the connector end is the same size and most thunderbolt connectors I have seen look the same in dimensions as the displayport connector.
Thunderbolt relies on active cabling - there are signal processor chips at both ends of a Thunderbolt cable. I'm not sure if a couple inches of passthrough circuitry would affect the signal, but I'd definitely want to see a dock tested with Thunderbolt devices before relying on it for more than display output.
Wow, didn't know about the circuits:
http://www.macrumors.com/2011/06/29/thunderbolt-cable-teardown-reveals-electronics-and-firmware/
Apple sells a decently long thunderbolt cable. I would attach that inside the dock and then out of it into something. It must have the electronics at both ends.
I'm waiting for someone to come up with an expansion tower with drive spaces and pci-e slots, something actually useful that fullfills the potential of thunderbolt.
Yeah, the tech built for thunderbolt has been moving like molasses! :) I use mine as a displayPort only right now for an external monitor.
I'm hoping for something like this, too. There's a PCIe chassis in development, but it would be nice to get both that and a RAID array in a single tower. I was planning on getting a Mac Pro for my next computer, but I'm going to be on the road so much over the next year that I don't think I can get away with it - hopefully the Thunderbolt landscape will fill out a bit and not leave me feeling too forlorn with a macbook pro.
