FatDaddy
Switching to FCP and want to make sure I am ready with my set-up. I am going to Final Cut Studio after somethinig has changed and my FCP 5.1.4 with a Canon XH-A1 will not work (I have tried many things and checked lots of forums - still no go).
I am going to run FC 2 on a 2.0ghz intel Macbook pro (1st generation model) with 2 gigs ram, 7200 rpm drive and Radeon x1600 256meg graphics card. I am at OS 10.4.11 with QT Pro 7.1.5. I use a g-raid 500 gig drive connected through firewire 400. I want to edit HDV 1080 24F from the Canon XH-A1.
I could keep everything as is after FCS 2 or go to Leopard and get a ExpressCard 34 firewire 800 card to run to the drive. I can also clean install leopard and start fresh. Would this be best? I am assuming firewire 800 through the ExpressCard would be best, but will it change anything? FYI, I run one 24" monitor along with the laptop.
Question for you - Should I: get FCS 2 and keep everything else same, get FCS 2 and Leopard with a clean install, get FCS 2, leopard and the ExpressCard 800 adapter.
Thoughts?
Thanks,
john
Thoughts?
Thanks,
john
