New CompactFlash standard proposed
Sony, Nikon, and SanDisk submitted to the CompactFlash Association a new standard for CF cards that hold up 2 terabytes. That's enough to hold eight hours of uncompressed HD video video (12-bit, 1920x1080) at 24 frames per second. They also specify that it read and write at up to 500 megabytes per second, which is enough to handle up to 168 frames per second of uncompressed HD.
The cards would be about the same size and shape but a little more rugged. They would use the PCIe interface. They also would use less power.
As you may know, this is just a spec for the connectors, basically. To reach that capacity and speed, the actual flash memory chips inside the card also have to be able to handle that capacity and speed. Sort of like how today the current CF card spec allows up to 128 GB and 167 MB/sec., but most cards do not actually meet those specs.
Also, don't ask me what happened to the CFast spec (which used a SATA interface instead of PCIe and went up to about 300 MB/sec.)
Still, with flash doubling in speed and capacity every year (about) and halving in price every year (about), you might expect such a card in about five years for $256, or about $32 an hour (2 TB = 8 hours, $256 / 8 = $32).
http://www.computerworld.com/s/article/9198599/SanDisk_Nikon_and_Sony_develop_2TB_CompactFlash_card_spec
I wish this option was out right now for a couple hundred - then we could use it in the IKONOSKOP camera.
With that card, some kind of sata card reader, and an off the shelf battery of some sort, it would be a dream!
Sounds amazing. Uncompressed video on CF cards are the future! Forget P2 Cards. Forget SxS cards. Forget SD cards.
