Neumann KM 150... Any thoughts??
HansonD
Topic pretty much says it all. I'm considering this mic (KM 100 powering module and AK 50 hyper capsule) to use for interior type situations. Basically as a cheaper alternative to a proper Schoeps setup. It has my interest because of the amount of accessories available for it... swivel, extension cable etc.. Any and all opinions welcome and appreciated, I don't know anyone who has one of these to test out.
Thanks,
-d
Exelent mic , we have these in rentals .a bit more problematic with rf around
the best works with 100f preamp on the boom as it cuts low fq at 80 hz
Thanks Oleg,
If I'm filtering low end at the mixer is the 100 f still an advantage? Also would you care to compare this one with the Gefell or Schoeps? Another way to ask this is would you consider this mic to be in the same professional class as the cmc641, mkh50, etc..?
its always better filtering on the mic it self
same class
sound wise no real difference from others ,more narrow pattern then the 41 more like mkh 50 - handle high spl better then others
