Netflix watch instantly quality question
REHov520
This has been bugging me and I can't find an answer so I just decided to ask. Can someone explain to me the difference between connecting my computer monitor to an HDTV with a VGA to HDMI cable, and going through some other device like an xbox360 or ps3? It seems like if you set your monitor to the same resolution as your HDTV, these two viewing methods would be comparable, but in reality the straight off the computer method looks far inferior to the other way. can someone explain why this is?
netflix doesn't do hd streams off their website. Not sure if the Xbox or the PS3 do, but the Roku does, and they look pretty darn good. when the quality of the stream drops out of HD and into the top stream of SD it really loses a ton of info. Compression artifacts abound.
My first experience with netflix instant watch was on the Xbox. Some are HD while others are just regular DVD quality I believe. When I loaded the browser instant watch, I was disapointed a bit. Definitely still watchable but the compression really bugs me. Particularly in comparison to that of the Xbox, which looks great and also has a good range of HD pieces.
To answer your question the xbox and ps3 versions streams are not compressed anywhere near to the extent that the web browser version is.
So regardless of your resolution on your computer monitor or whether you can output an HD signal to a large HDTV, two completely different files are streamed to you on those two mediums. One looking far superior to the other. (Xbox/Roku/Ps3>Browser)
