Nesting issue: Changing Timebase 23.98 to 29.97
Eatsnax
Working on very large project. Some footage is 29.97 others are 23.98 due to footage coming from different sources. I transcoded all footage so one batch is Pro Res 23.98, the other batch is Pro Res LT 29.97. I now know that I should have transcoded the 29.97 to 23.98 so all footage is the same. But I didnt.
Created a Master Sequence to drop all the edited scenes and nest them back to back on a 23.98 timeline. The seq's that were 29.97 I had to change to 23.98, otherwise it wouldn't nest. One of the scenes I changed the timebase and nested no problem. The other scene, when I do it, the audio is out of sync. Now mind you these at seq's that are Multiclip. But I dont think that matters. Because one scene is fine.
Any suggestions?
I figured it out. It was the Audio Rate, it was set wrong. I set it to 44.1 and all is good.
