Negative fills
Polaroid22
Hello,
I am looking for
something like this, that can be used for negative fill. I am not sure what these are called?
A reflector with a dark side could also be usefull. Are there any big square ones, that are still very portable? (I will need them when I go Trekking, so pretty small package, that turns around is something quite good sized would be great :D )
thanks
I don't think 4x4 flags would be very portable for when you go trekking.
You might consider a couple of inexpensive 5 in 1 colapsable reflectors that have a black side as well.
In the situation shown...I would think they are using those as fire control. eg stopping the breeze blowing the flames and embers around or onto the actors.
Big by definition is not very portable.
I would get regular 4x4 floppies, they are always needed on set. And they can be a courtesy, neg fill, wind screen, and of course cut light. But don't get the reverse floppies, you will never see a more inraged grip when they look for a floppy and can only find a reverse floppies.
