Need to make an NTSC DVD. Help!
Steve Shovlar
DVXuser Sponsor
OK I am in Pal Land. I have shot a wedding in 720P50.
I have had a request frm the bride to provide two NTSC dvds for her family who live in NTSC land.
How do I do this quickly and easily? I am using FCP7 and DVDSP.
Thanks in advance.
Can't they just play it on their computer? Otherwise, there's a google for that...
Noah
Possible solutions(from best to worst):
-Recommend the couple to buy a cheap multi region/format/voltage no name DVD player (about $20, much cheaper than conversion cost)
-Buy the nattress conversion plugin($100) to do a proper conversion in FCP:
http://www.nattress.com/Products/standardsconversion/standardsconversion.htm
-Use the compressor to convert the finished QT movie from PAL to NTSC, then compress again for DVD. (free, acceptable result)
-Import your QT movie into DVDSPRO and choose the NTSC format to build.(free, poor choopy result)
-Take your PAL DVD into a video shop that does PAL-NTSC conversion and let them do it (Most costly, almost as bad as prior solution)
Hope it helps.
Thanks for the advice. I suggested the multi region DVD player and they dismissed it straight away. They want to take the dvd around with them to show different families. I will check out the Nattress plugin.
Cheers
Steve
