jakegreene
I'm trying to create a geyser of water that will shoot out from a crater in the ground and into the air. I don't have the budget to rent a water truck, and only have access to a standard water spicket which has an output of 55-60 psi.
Someone suggested that I use a 'pressure pot', which is a tank you fill with water and then use a compresser to pressurize it. The result being that releasing the output valve causes the water to shoot out of the tank, but only for a few seconds...
I've never used a pressure pot and am not convinced that this is best solution to my problem.
If anyone has any bright ideas, (with or without the pressure pot), please let me know! It would hugely appreciated!
