Nick Royer
Hi All,
I'm in post on my first feature and need some advice on editing and mixing the audio. This is a micro-budget production, so I am having to do this myself without much prior experience in this field.
Sound Editing:
First off, I have reference audio for most (but not all) of the scenes in the film. However, I am using this basically as just a reference. I may pull some sounds from it, but this film has some unique challenges that basically mean that the reference audio isn't usable in the finished product.
This is an end-of-the-world picture, and the premise is that there is no oxygen - so while there is wind noise, there can't be any sounds of life in the background, such as birds, cars, people, etc.
I've recorded ADR with the actors for every line of the film. There may be some areas where we don't use it, but my method here is to sync up all the ADR, then build the scenes around that clean audio, recreating the background sounds and ambiance. Given the unique nature of this script, and that we didn't have the budget or crew size to record very good audio on-set, this seems like the best option.
So - I need some advice on how to build up those background sounds and manipulate the ADR with EQ's, etc, to give it a nice sound. The ADR recordings I have are very clean, so there is a lot of room to work with there. Also, how much foley is too much? Should I focus on recreating every natural sound, or just try to capture the dialogue, background, and key FX sounds.
Sound Mixing:
After I get the sound editing done, I need to do the mixing. This for me is the bigger challenge as it is something I've never worked with before. I'm working in Audition on an iMac.
What are the norms for 5.1 mixing for theatrical and for DVD/BluRay? My main concern is where to put the dialogue. Do you keep all dialogue on the center speaker only, or pan it? I know that both approaches have been done, but what is standard?
If dialogue stays on center speaker, you then use the other four speakers for background and FX, and keep those off the center speaker?
And how about the subwoofer, what goes on that?
I have done some reading on these things, but wanted to establish a way forward by figuring out what is the most common way to do the mix. I also need to figure out how to get my hardware hooked up. I'm wandering if I can somehow use TB>HDMI, then go to my audio receiver to drive the speakers. I do have an excellent speaker system to mix on, but I'll need to calibrate them to accurately mix.
Any suggestions/thoughts would be much appreciated. Thanks!
Sound Editing:
Sound Mixing:
