suicdekng
My gaffer just dropped off my short film project to work a feature, so I am currently in need of some advice that would usually come from him.
I'm new to DPing, and as comfortable as I am with lighting interiors with anything from LED to quartz to HMI, I am not at all up on the outdoor shooting.
We have a few c-stands, flags, several reflectors, bounce cards and nets. Nothing is larger than 42". If the weather does what it claims to do, We will be shooting with the sun rather high (not directly, but mostly from above).
Due to some of the shots needing to show the actor standing on the street, a large overhead scrim's shadow will end up being visible in some shots. There are, however, several close and mid-shots that will NOT show the ground, so a large scrim could be used.
The question is - should I get one? (rent, naturally) I can get a 12 footer for just over $100 for the shoot. As much as I google and as much as I browse these forums, I cant find ANYTHING about outdoor lighting. I can find some cheap and indie tricks to get better shots, but I really want to know what one would do outside in broad daylight to get a great shot if one had several hundred dollars to put into it.
So, contrary to the usual direction of questions here; what can I spend extra money on to make an outdoor daylight shot better.
Thank you all!
Thank you all!
