Need help to create script
Hi
I'm wanting to create a Vegas Script, pretty much the same as the add timecode to all media script, but as I'm in PAL land it needs to add the PAL timecode and not the NTSC code.
I've tried creating a new preset and tweaking the existing script to use it, but so far I can't get it to use anything other then NTSC.
Does anyone have any idea how I could do this.
Nick
You have to create a new Preset in the Timecode effect, using SMPTE EBU timecode. Then, substitute the name of that preset between the quotation marks in the line:
//String presetName ="SMPTE Drop (29.97 fps)"
Yip tried that.
I also copied the original script, changed the NTSC preset to my new PAL preset and renamed and saved the new script so that I could see both the original and new script in the Script drop down list ( tools > scripts > ) but it still uses the NTSC timecode.
I'm pretty much at a loss at this point, directing the script to the new preset should do the trick.
