Gentlemen,
Need your guys help on the following Dimmer mini-fill item:
http://www.bhphotovideo.com/bnh/con...il&Q=&sku=113986&is=REG&si=feat#goto_itemInfo
Can the Handle clamp that comes with the mini-fill be fitted on the DVX-100 shoe mount? Or should I just order the Dimmer mini fill without the handle clamp and order a shoe mount instead? ???
Since I mostly use the DVX for my family function, friends wedding, is there any accessories that you would recommend ?
Thank you for all the help.
