Ok, so it took a while (thanks to all who gave input), and now I've narrowed down my options to two sets of legs which include the half bowl leveller for my fluid heads to attach to. i will list the specs. The main difference is that one is 547B has a mid level spreader, and is your typical pro video tripod type legs, whilst the 745XB has standard tripod legs like you would expect for stills.
Manfrotto 745XB
[FONT=Arial,Helvetica,Univers,Zurich BT][SIZE=-1]Load Capacity: 15.4 lbs (7 kg)
Maximum Height: 55.1" (140.0 cm)
Minimum Height: 12.2" (31.0 cm)
Leg Stages/Sections 2/3
Folded Length: 25" (63.5 cm)
Weight: 5.3 lbs (2.4 kg)
Flip Lever Leg Lock w Independent Leg Spread[/SIZE][/FONT]
Price £175
Manfrotto 547B
Center column: no center column
Closed length: 86 cm
Colour: black background Color
Head bowl: 60mm
Leg cross-section: round
Leg sections: 2 number
Legs tube diameter: 16. 20 mm
Load capacity: 15 kg
Material: aluminum legs and technopolymer
Maximum height: 142 cm
Minimum height: 79.50 cm
Spreader: mid level - fixed arm length
Weight: 2.30 kg
Price £193
Obviously, the 547B has a much larger load capacity. But I'm fairly lightweight, I don't expect this to be an issue. I plan to mount a small slider on it too, and so the min height of the 745 would allow me to get much lower to the ground options (which i will likely use). I also feel slightly swayed by how the appearance of the 547 would give me more 'street cred'.
Anyone fancy pushing me one way or the other? I'm rather indecisive!
Manfrotto 745XB
Price £175
Manfrotto 547B
Head bowl: 60mm
Weight: 2.30 kg
Price £193
