It sounds like your hard drive is full. It's not a Vegas settings issue.
An external drive can be handy.
:shocked:can anybody help me with my problem and also what is an external drive?
Deb
Right click on your C Drive and what does it tell you is remaining in memory ? Free space ?
Oops
Yeah .. you're running out of space.
Either dump footy you no longer require or run down and get an external drive like Blaine mentioned; should be plug and play; make sure it's Firewire.
You can either transfer all of that old footy over or you can simply use this new drive for this project.
If you want to permanently remove the footy you put in there; then simply delete them.
If you want to keep the stuff, an Ex Drive is mandatory.
I'm on XP
But if you are talking about cleaning it up ?
Tools > Internet Options > Delete Temporary Files (pages images etc)
For removal of Software . Add Remove Programs under Control Panel
If literally wanting to find the media nad axe it and you're not sure where it all is ? Do a search for Media (All Video) and then Delete away
Also, check your trash and make sure that isn't to the rim with Gigs.
6.49 GB... or about 30 minutes of video. 15 minutes if you plan to edit and render it back out.
Go get an external hard drive. The largest you can afford.
Costo has a 750 Gig Seagate external drive for $180.00 - great drive too.
cheno
