wangtrirat
I've made several DIY here.
Overdrive Metal Halide 150W to 250W. i've found that color are more balanced from specification on box at 6000K.
Achieve more red and make pretty Balance color.
in fact it is arctube that i shatter outer bulb UV cut glass off and put it in 500W halogen worklight. sound scary but it's for experiment
rogar-BigGrin(DBG)
in real world use have to use UV cut like other HMI Does.
this is that it's looks like all this pics are capture from Bold 9700 with portrait WB
This is Arctube itself
Note: This is experimental so bulb will not be in properly fixture. i'll buy more one to use within it's UV cut envelop and overdrive to 200W so reddish color will reduce significantly.
Video taken from Panasonic DVCProHD (i can't remember detail of model) at Preset WB 5600K this one drive with Magnetic Ballast ,When experiment complete Electronic gear will involved to the project.
:cheesy:
:cheesy:
