Need Audio Card - Interface Suggestions
Traveler features
Traveler features
Here are the Traveler features if anyone wants to see them:
The Traveler-mk3 from MOTU can function as both a FireWire audio interface or stand-alone mixer, and is primarily engineered for high-end mobile recording applications. Equally suited to any other audio situation, the unit delivers 4 high quality microphone inputs, and can be powered from either a computer's FireWire bus or via optional battery packs. It also features internal DSP-driven mixing and effects processing.
As an interface or stand-alone mixer, the Traveler-mk3 provides 28 separate inputs and 30 separate outputs, including 4 combo microphone/instrument analog inputs equipped with pre-amps, individual 48V phantom power switches and Digital Precision Trim controls adjustable from the front panel or CueMix FX software. DSP effects include a 60-second reverb, 7-band parametric EQ and various flavors of compression/limiting.
• Compact, fully featured FireWire interface
• Microphone, line and digital inputs and outputs are all discrete - no channel sharing
• 4 combo jacks provide either XLR microphone input or Hi-Z 1/4" guitar input using transparent preamps with phantom power, pad and 53dB of gain per channel
• High-resolution recording with the ability to operate all analog inputs and outputs at sample rates of up to 192kHz
• 16 channels of ADAT Lightpipe, 8 channels of SMUX (96 kHz) or two pairs of stereo TOSLink with the ability to mix and match formats between the two banks
• Stereo 24-bit/96kHz AES/EBU and stereo 24-bit/96kHz S/PDIF inputs and outputs
• Wordclock in and out
• On board CueMix FX is a flexible 28 input/16 bus mixer with on-board DSP effects, including classic reverb with sends/returns, plus modeled EQ and vintage compression on every input and output
• Multiple CueMix FX mixes can be created for monitoring or to add send/return loops for external processing with no added latency
• CueMix FX software provides real-time FFT and spectrogram "waterfall" displays for visual analysis of individual signals and entire mixes
• Can function in standalone mode
• Built-in SMPTE time code sync can resolve to, and generate time code without the need for an additional synchronizer
• Front panel volume control for monitoring with stereo, quad, 5.1, 7.1 and user-defined surround monitoring setups available
• Front panel meters or activity LEDs for all analog, digital and MIDI I/O, plus SMPTE sync, tach and lock LEDs
• Powered via the FireWire bus or using optional battery power packs
Yes Apple and MOTU seem to have a very close relationship. The Traveler is quite well thought of for production recording. Folks have said it has good preamps and works well. I have had mixed experiences with MOTU, both real good and pretty negative. From what I hear though support is again on the good side of the curve. It is not really a mixer but does have some mixer functions. Or rather it is a mixer but not one your going to want to use. Production people are using it as a front end for BoomRecorder or Metacorder.
