I'm building my first dolly and have encountered a problem with the wheel assembly. I'm sure it's a rookie mistake but I can't seem to figure it out. I think it's the wheels I'm using but would greatly appreciate some help.
The plans I'm working from say " put a 1/4-20 2 inch hex bolt through the wheel followed by 1/4 flat washer, 2 nuts (for spacing), 1 1/4 fender washer (then the rail for the base) another fender washer and a final nut."
Problem is, there's nothing holding this harware to the wheel. As picutred, the bolt goes completly thru the wheel. I tried putting a fender washer on the outside of the wheel (like a hub cap) and various arrangements of nuts and washers between the wheel and rail and the wheel either binds or spins itself off the nut.
Please identify my rookiie-fabricator error! Do I need wheels with a smaller opening for the nut?
Thank you
Thank you
