j1clark@ucsd.edu
I posted this in the GH-1 section, and got no response over the last couple of days. Perhaps it is more apropos for the Premiere section.
I had the opportunity to do some tests, and here is something that may mean I'm not setting the JES conversion parameters correctly. (I've not tried commerical packages since Neoscene crashed on my Mac OS X system...
What it looks like, is JES in converting the data, boosts the 'black' level to 7.5% IRE, and also seems to lower the max to slighly less than 100%.
I composited the Premiere views to show the difference. I took a spot meter reading off of the sunlight wall, then opened up 2 stops, and shot. The MTS wave form shows the 'whites' just reaching the 100%, and I've turned off the 7.5% radio buttone, and so the 'blacks' are at 0%.
The ProRes version shows reduced high values, and stepped up lows.
