Gary said:Since I rarely shoot without a tripod, I attach the charger to the battery case and hang it on the tripod. There is some sacrifice that we must adjust to. It's seems to me much safer than trying to gamble with voltage variations of power step downs.
We have them. If you search the forum, you will find a number of members here that use them.MarcM said:Anyone know where to get an adaptor to plug my DVX into a car cigarette lighter for power. Something that converts the 12V car battery to the 7.6V required by the DVX.
Gary said:I too was looking for a solution to powering DVX from battery and I also have a load of NP1 Sony batteries. What I did was get a used Np1b battery case from ebay and wired a female cigerette lighter plug to it. I've never been comfortable with stepdown dc converters especially because of the possibility of overpowering my camera. We already have the proper utility ( the charger). I simply went to Walmart and bought a small 75 watt continous 100 watt surge inverter. It's about the size of a cigerette lighter plug with a small ac female on the end. It's regulated and will shut down when the voltage gets too low. I can put the whole thing in my back pocket and pop in a new battery when needed.
You can basically power any low draw ac accessory that you own.
A Li-Ion battery freshly charged will have 8V on its terminals. As it is being drained, it drops down to about 6.5V. The camera is designed to accept any voltage in this range, as it has internal voltage regulation. Even a bit over 8V is not going to kill it, as there is always some design margin to handle short term overvoltage.GenJerDan said:Hmmm...just what IS the voltage?
My charger says 7.8 vdc. The camera says 7.9 vdc. The batteries say 7.2 vdc.
Are the specs really just 7.(mumble mumble)?
Dan
