My G35 arrives!
dmc
Woohoo! The UPS dude just dropped off my G35!
I'm at work so I'll have to wait 'til I get home but...
I popped open the box and slid out the small 1300 Pelican case that it ships with (very nice touch) - the build quality really is excellent - it's build like a tank. Very tight tolerances on both the camera side (I got it with the HPX170 mount) and the lens end of the adapter.
I'll be busy tonight.
dmc
I placed my actual order <gulp> at the end of Feb. and it arrived this morning. That said, Jonathan did stay in pretty consistent contact with me and offered to let me use the Universal mount while they were working the bugs out of the HPX170 mount. Of course NAB did delay things a couple of weeks.
Yes it was longer than I was expecting but I never once felt like I was being ignored.
dmc
Dmc, congrats man, now if you have the time, some test footage please. would love to see more footage of this thing in action.
Ninos
Congrats dmc!
Anyway, which rail support are you pairing with the G35?
Would love to hear you take on the G35.
Enjoy!
Yeah, I'm really jazzed about finally getting it!
I'm not really sure about which way to go with the rails and support just yet. It definitely needs support. The 170 has that pesky offset (to the right) in it's threaded mounting hole, so whatever baseplate I use will need to be able to accommodate that. I was thinking of using the Red Rock system and follow focus but I'm not sure if it's baseplate can be slid left to right. Anyone know about this? Any other options? I know that Jonathan @ Cinemek has plans for a system in the near future but I'm not sure that I'll be able to wait.
I'm REALLY looking forward to doing more testing with it although I've got a lot of things on my plate this week.
dmc
dmc
CONGRATS, CONGRATS! i bet it felt like forever huh, i don't know that much from direct experience about the REDROCK system, the follow focus is good , you need to use the big len rings though. I could get only two of them to fit my Nikons. The RR lens support i'm not familiar with, Jonathan has his own, but i don't think it's ready for the public release yet. The Zacuto baseplate and lens support is what i have and its simply fantastic, and so solid. i can pick up the whole rig and hear no creaks or twisting, etc... You will need full adjustability with the riser and baseplate.
I needed about 24 inches of rods with my mattebox and the lens hood on the nikons and a donut.
The RR hand held rig , shoulder pad and handles, well blue is not my choice of colors and it looks too plastic i think. Remember mate, very important, your rig is going to be quite front heavy, you need to be able to slide this baseplate towards the front . Zacuto makes what they call a Z balance. This is cheap to buy and it slides on your rods and allows you to center balance your camera on a tripod evenly.
Let me know if you need help with back focus or flanging the lens
Hey, shoot the Empress for me, huh?
Cheers
redrock baseplate is adjustable to compensate for the offset of your cam. i don't know how heavy the g35 is but the m2 isn't exactly light. the rr rods should balance just fine with your rig...
you can go zacuto if you want. their stuff is the best. however it is expensive as hell. the redrock is not one bit less solid. maybe a little heavier and not quite as elegant but can be had for way way way less cash.
Cheers
Thanks Phil for your help on this.
Yes it did feel like forever - I'm not good at waiting ; )
I read in another post of yours (a different thread I think) that you had really got the back focus dialed in right around Z49ish. Maybe you could help me with this.
Although I just got the unit but I've been loath to adjust either the back focus or the flanging - I would have guessed that given the mounts I ordered (HPX170 and Nikon) that each would have been properly adjusted then locked down at the factory. While they seem to be adjusted okay, it sounds from what you're saying that the tightness in the image can be improved a little - also not having to zoom in quite as far is another plus re: light loss.
btw - My office is right in Bastion Square downtown - I can hit the Empress with a stone.
I'll grab some shots for ya - just for ol' time sake. ; )
again thanks,
dmc
thanks for the info Cheezweezl (great name btw). I really have been leaning towards the RR stainless rods etc., especially since I'll be getting their follow focus and matt box.
again thanks for your help!
dmc
again thanks,
dmc
Oh my goodness, Bastion square wow, brings a smile to the good ole days.
Alright, Mark with tape where you are now with the Nikon mount, that way you can always go back. Camera should be level and flat , focal distance on lens should be in safe zone. Minimum close, Max Wide, etc.... Make sure the lens you are using and the optics (glass) on all components are clear and clean. No swirls, no haze etc...... This includes the Cinemek, shine a flashlight across the lens /Achromat plane and double check everything is clear.
You will need the sharpest monitor , preferably with PtoP or peaking if available on the camera or monitor/lcd. Does it look sharp when you zoom all the way out? How far do you zoom in now? i get between 48 -51z
Are u using macro focus to achieve focus?
After it is set remove auto focus.
Okay the flanging is easy, us the widest lens that you have for me it was a 24mm f2. You can zoom out all the way till you see the full circle, Slowly undo the small allen inset and tweak till its loose. Now ever so minutely shift the mount forward and backward, watch the focus tweak in and out , this is dependent on how much play (breathing room)you want past infinity , perhaps you want a 1/8 or 1/4 turn to be able to double check the focal point for crisp focus. Zoom in till there is no vignetting
or soft corners.
If you are using "peaking ", it should display all the way across the plane on an even flat wide shot, no objects that are in the foreground should be peaking, you can rack between these and double check. It should look sharp to the eye, if you shoot a chart, (i can email u some hd charts if you want to print them out.) the small horizontal lines should flicker. Bingo zoom all the way out , they flicker still!
To gain more exposure you can go to 1 / 32 shutter and then get more edge focus by stopping down
Hope this helps, Good luck , keep me posted! Victoria is a beautiful place to shoot!
Hey Philip,
So cool of you to take the time on this dude - I'm gonna give it a try right now.
Definitely email me your charts if you get a second - dmcgrath@inlightentertainment.com
Just to be clear, you're using an EX-1 to do this with correct? I wonder if the actual zoom amount, (in your case Z48-50) might be a little different on my 170??
btw - I'd love to hear your impressions of some of my "first week" test footage - sans adapter. Heads up re: the lighting, I'd been watching a lot of Dario Argento that week. ; )
check it out here:
http://www.vimeo.com/3829458
thanks - REALLY appreciate your help!
dmc
dmc
the baseplates on the RRs will not accurately accommodate a hpx 170, when meeting up with your matte box it will be off by a couple centimeters. I designed and machined a replacement adapting plate for my setup to get around this.
Sorry all it's late....the redrock will adjust accurately but only if you don't run rails clear through. I made my plate because I wanted to be able to run through rails and be able to store the baseplate set up with 6" rails in the given slot in the foam in the pelican case.
Hey Philip,
check it out here:
dmc
Yeah cool, love to see the test footage from the G35, just print out the charts as large as you can.
See if you can edge to edge sharpness, any CA ? no doubt the EX1 will be different , i 'm not sure how much, we need to get some feedback from HVX 200 users, that might be closer.
Just play around and test. You gotta have no life, lol
Cheers Philip
Hey SMGINC,
thanks for the updated info. I was just about to ask you if there were different versions (maybe a reissue or something) of those rods and baseplate since RR says that they will work just fine with the 170. I'm glad to hear that you figured out a solution - especially one that let's you store it without getting a new case.
again thanks for the info!
dmc
Cheers Philip
thanks for sending Philip! I definitely owe you a couple of "chewy" pints - next time I'm down.
dmc
