My DVX100BE has no 24p
yeah...umm...the difference between NTSC and PAL is 24P and 25P. With that being said, it's perfectly normal to have a PAL version of the DVX with 25P. If 24P is what you want, then you would want the NTSC version of the DVX. Hope this helps.
Are you living in europe? Because for broadcast purposes as well as playback, 24p is not possible ( not sure the technical aspects behind this i just know its true)
like static sea said, its the difference between NTSC and PAL
