Brian@202020
Here is the solution I made for distributing power to my AF100, Hyperdeck Shuttle 2, and a D-Tap. I used this circuit board inside this enclosure with this 1.7mm pin x 4.75 OD Bulkhesd DC power jack for powering the AF100. I had the D-Tap left over from something I no longer use. The D-Tap, which I use for powering my DP6, and power for the Hyperdeck Shuttle 2 is pass thru direct power from the battery. I soldered to the back of the battery plate, came out the side of the battery plate, came in the enclosure, and then split the power 3 ways, one to the circuit board, one to the Hyperdeck shuttle plug, and one to the D-Tap.
