brokenjack
Just thought I'd start a new thread to show off my homemade kino.
Basically it's built around Coralife aquarium fixtures and a mirrored reflector that came from the same pet shop.
The ballasts velcro to the back and they let me choose between 2 tube and 4 tube
The covering is black corregated plastic. Unit is held closed by 2 elastic velcro straps. Between the reflector and the plastic, is a sheet of aluminum to give stability. I used rivets. I used that black plastic wiring harness stuff you get at the harware or auto part store to hold together the wiring. Had to take out a section of wire to get the cables to match length since all the wires are coming out one side. I had to compensate for the length of one wire going to the far endcap. Hope that made sense.
As you can see, it mounts nicely on a c-stand so it can be positioned easily. It is also lightweight and can be extended on the arm. I used a rod welded to a 6"x 6" piece of sheet metal as a mounting pin that is bolted on with wingnuts, so it can be taken off easily if you need to stack it.
Here is the front. I creased one of the "barn doors"
Here is the light open. I flipped it around to let the bottom barn door fall. I was going to make the barn doors postionable, but it got so over engineered that I just figured I'd use flags on c-stands. The barn door can be clipped back to the stand out of the way.
Tubes are held in place by a strips of velcro strap riveted to the "plastic/aluminum plate/reflector" sandwich. The tubes can all be easily taken out and mounted/taped up individually. The end caps are a great feature to the aquarium rig. They are rugged and if you need to change color temp bulbs, it's fairly fast.
Here is the aluminum plate and mounting plate I used. Basically I went to my neighborhood metal working shop to get the rod welded to the plate, and I also had them round the corners of the aluminum plate.
Sorry for the lousy pictures. This has been a great rig, and we use it all the time. I recently used it on a HD shoot at 24p with the sony cinealta, and did not notice any flickering.
