Norman99
Finally finished and tested my DIY battery operated ( V mount 14.4V DC ) led project.
Just need a few opinions of it for possible improvement (s).
here are the specs:
Measures 12 X 6 X 3 inches
Weighs in without battery at 4.8 lbs
Power draw at full brightness is 72 watts
Passive thermal design ( no fan )
120 watt/hour battery lasts 90 minutes
Leds are the latest binned 5200K with well over 100 lumens per watt at rated full brightness
TIR optics as pictured are 12 degree spot ( interchangeable for 24, 35, 40 degrees )
Dimming is non PWM for flicker free non banding type.
4 pin XLR input for DC or AC operation
Input DC voltage range from 12 to 24 volts
Diffusion panel fits into grooved front slot in front of polycarbonate protector
21,000 lux @ 3m ( 12 deg, optics)
Weather sealed with high temp silicone gasketing
Mil spec potentiometers, teflon wiring throughout.
here are the specs:
