mainstreetprod
I ran across some LED camping headlights on Ebay with 56 LED's. Thought
for about $12 it might be worth a try as an on camera eye light, so I ordered one. Although Hong Kong was listed as place of origin, it was shipped out of New York and came quickly.
Now I needed to adapt it to the hot shoe. I dug around in a box of misc camera light parts and found a hot shoe adaptor from the bottom of an old light, complete with knurled nut. I cut off the headlight strap, drilled a quarter inch hole in the plastic bracket and put it on the HVX (see photo).
There are 3 brightness settings - 10 LED, 27 LED and 56. A good range.
The pushbutton switch seems solid. The "flashing" setting is useless unless you want to stop traffic while filming. Build quality is OK for a $12 device.
If dropped it will break. So buy another one!
Takes 3 AA batteries. Duracells or similar should last several hours. They claim
30 but my estimate is probably closer- especially with all 56 LED's burning.
As has been commented before about these lights, they are quite blue. I simply cut a 1/2 CTO gel to fit and still get a good amount of corrected light.
With the gel, the color temp is close to daylight. I posted a with/without light
comparison here:
http://www.dvxuser6.com/uploaded/21102/1185415537.mov
Since it was still daylight (about 7pm), it was almost impossible to see the
light in person. Looking at the clip, though, the difference is there. Definitely
fulfills the purpose of eyelight. in darker circumstances, could light your subject
enough for decent video, especially with the DVX. All in all, not a bad way to spend 12 bucks. Spend $24 and keep a backup in the bag. :thumbsup:
Note: the base of the light touches the mic holder when attached- making it tilt
slightly. I will have to grind a bit off to make it sit level, or remove the holder.
comparison here:
