G
Guest
Guest
I am shooting a music video 2moro. I am going to edit w/ VV4 and output to DVD using DVDA 1. Should I film 24pN or 24pa? PLEASE HELP!!!!!!!!!
Hodges
Hodges
In either 24P or 24PA, you're going to have progressive frames that get divided into fields, and as far as I understand DV, each field is compressed separately (i.e., I don't believe that DV can compress a full frame, it compresses fields). 24PA will always keep the progressive frame's fields together in the same frame, whereas 24PN will occasionally make a "frame" of one field from one 24P frame and one field from the other 24P frame. But if the fields are compressed individually, it shouldn't make any difference, should it?In the case of 24p, instead of two fields, you have two frames compressed together.
This statement is confusing. I think what you're trying to say is "each 24P frame can be extracted from a compressed frame that includes fields that were from that same frame". I don't know what you mean by "two identical 24P frames".When you shoot 24pA you'll always be able to extract each 24p frame from a compressed frame that includes two identical 24p frames.
Yes, but no. You do have to extract some fields from compressed frames that were encoded separately (a field from frame 32, and a field from frame 33, for example) but the uncompression process isn't lossy (or at least it shouldn't be). The compression is lossy, but the uncompression should result in a bit-for-bit reconstruction of the compressed data. The loss takes place at the time of compression, that's when data is thrown away. The uncompress should theoretically be lossless.When you remove the 2:3 pulldown from 24pN footage you end up having to extract some frames from a compressed frame that includes two different 24p frames. Because the compression is lossy, you'll lose some quality when the 24 p frame is extracted.
