Multiclip woe - keeps ignoring the multiclip view when editing
andrew00
Hey,
So I'm trying to a multiclip edit but FCP keeps removing the multi angle view when I run the timeline.
I.E. I've set up with my multiclip of the timeline, all the respective angles appear on the viewer, which is set to open. However as soon as I press the space bar on the timeline and play the video, the viewer loses the multi angle view and goes back to just playing the first video.
When I pause it will go back to the multi angle view, but that's useless because I need to be able to see all angles to edit!
confused..
A
This might help: if you render your sequence containing the multiclip,
then you can't see the angles in playback. So just go into your your
Render folder and trash those renders.
Les
Les
Great advice, Les. :thumbup:
I learned this lesson after countless frustrating hours with the same problem as above. A good rule of thumb when doing mulitcam editing is to take the auto render setting off. If you walk away for a while, your mulitcam timeline will render and become a nightmare.
