Multiclip Editing
I just finished attempting a multicam edit with 2 camera angles. I was switching in real time and as it was playing, all the cuts showed up as blue markers in my timeline. Then once I pressed the spaebar at the end, they all went away. I need it done in 30 minutes now. Do I have to let it play though?
Are you certain you were CUTTING to your angles and not SWITCHING? Switching jsut changes the angle on the entire clip, a cut actually makes the edit. After you let it play, the markers shoudl disappear and give you the edits you made. Does that answer your question? If not, could you restate it?
Well what happened was I was doing the multicam edit in the window with the two angles. I was just using the number pad to switch between the two. I thought something may have been wrong because it was playing live in the canvas too. I thought it wasn't supposed to do that. But ya after I was done switching, all the blue markers disappeared but there was no edits there.
It is supposed to play in both during your multicam edit. Once you are done, set you sync back to 'off'.
Using the keypad will only switch. You want to cut. Simply re-assign the keys using the keyboard layout, or click on the thumbnails in the viewer.
