Hi,
I need to do more research, and already asked some time ago about gitzo legs.
But maybe some of you already have the perfect solution.
I'm looking for a tripod & head combination that works for video as well as for photo.
Of course you can use a video tripod and head for photo with certain limitation but I'll make a list beneath.
Can go high as wel as very low to the ground
The head is either swappable (easy, fast) or 90° vertical orientation is possible (probably swap option)
Is sturdy and solid, but doesn't have the weight of a cinema tripod & head
Can be used with lightweight camera, but also rigged out camera (still lightweight though) Between 1kg and 3kg
Easy to carry and to use, but no need for hiking or such
Of course the heavier the sturdier (most of the time), I'm aware of that.
And budget friendly probably makes certain things difficult as well.
Sachtler Flowtech legs for instance are out of the budget. Besides, I've used them on a shoot and wasn't actually that fond of them...
Thanks!
Thanks!
