Hi,
For my first topic starter I'm gonna go ahead and dive into an issue that has been puzzling me lately, and also confusing my search for a new mixer purchase...
The problem:
It's obvious that multi-track (3+) digital recording on set is becoming standard practice these days. I mean when you're running a 744t or deva on set the obvious thing to do is give each mic in your setup its own channel if possible. It's not uncommon to get a request for discrete tracks from post so that they have as many options as possible for cutting. However, while new recorders are heading full steam in this direction it seems to me that 90% of mixers out there are still 3/4/6IN x 2 OUT designs. What gives? Stereo mixing is an essential feature of a mixer (wouldn't be much of a mixer if it didn't) but I feel that discrete outs is also becoming just as important these days.
There are a few out there though (I know that many of you are shouting out 442! as you read this) that have direct outs per channel. I was amazed by the 442 when I got my hands on it and it seemed to be the perfect companion for feeding the 744T with discrete signals. But I soon discovered that those direct outs on the 442 are pre-fader auxs, I can see how this would be desirable for feeding other types of equipment but for on the set mixing to a multitrack recorder I would definitely want my mix to translate onto the harddrive. I mean what the hell? The only real control of the direct out signal is on the little bitty retractable trim pots, and not the big ergonomic faders... it seemed rather counter intuitive to me.
So I kept looking for a mixer that provided this seemingly simple functionality. Honestly I'm surprised to see how few mixers actually have been designed to get discrete signals out of the box. SQN has a routeable, dual bus machine, as does Kamesan, and possibly Cooper but all these super-pro level pieces are completely out of my league for the time being.
My biggest lead so far has been on the PSC AlphaMix. PSC is a brand I know many of you have mixed feelings about but I'm impressed with the feature set of the alpha. It has some interesting features that I haven't seen anywhere else, and it also has, to use PSC's parlance, individual line-outs per input. This grabbed my attention and I was curious to know if these were pre or post fader outs, so I emailed PSC. Ron myers responded a day later and told me that they are normally pre-fader (big knob) outs however he had a look at the schematics and found that it would be an easy, non invasive modification to make the line outs post-fader (he said they even tested the modification and that it worked perfectly). So as of now I'm seriously considering the alphamix.
Hopefully there's enough topic here to get some talk going. What are your opinions on multitrack recording on set? How do you get a discrete signal path to hdd and how do you fine mix for it? Would post-fader discrete outs really be desirable or am I getting sidetracked by an unnesecary feature? I'm looking for opinions and suggestions alike.
cheers
-d
The problem:
cheers
-d
