I am using DVD Studio Pro 4 on a Mac PowerPC running OS X Tiger.
I am trying to make a multi-angle clip. I have created two MPEG video clips in Final Cut Pro and rendered them in Compressor. I used the exact same compression on both and they are both the exact same length in frames (interestingly though, one is listed at 1.04 MB and one is listed at 1.03 MB).
I can add either to V1 stream. When I add the second to V2 stream, I get the error: "Cannot add the entire video asset. The Video Asset...is only usable up to 00:00:41:00. Us the first part of the asset anyway?" If I click "use anyway," a small portion of the second stream is added and I get the error "Alert Incompatible GOP structure. Last Valid Time Code at 00:00:41:00."
I found that even though only a small portion of the V2 stream initially is added, I can take the mouse and expand that portion up to its original size. So I thought I solved the problem. However, when I go ahead and simulate the DVD, I get the warning "Illegal angle situation. Only the Man Video Angle will be simulated."
I found that I CAN add the same file to both streams V1 and V2 without an error.
Any ideas on how I can create this multi-angle clip? I have tried re-rendering the video (even making them different lengths) and nothing seem to solve the problem.
Thanks,
Kelly
Thanks,
Kelly
