Steve House
One doesn't necessarily 'have' to use a small condensor - you could, for example, use a pair of AKG C414. With its switchable pattern you could set one to cardioid and the other to figure-8 for M/S or set both to figure-8 for Blumlein. But if I had a small diaphram cardioid and was looking for a figure-8 to use with it, I'd look first for a small diaphram. The point is to shoot for a match in timbre, sensitivity, etc, for the same reason you would try to use a matched pair of mics for X/Y micing. Using a small diaphram mid with a large diaphram side could sound strange.If that is the case, you would have to use a small condenser, probably a small diaphragm condenser for both the the figure 8 and the cardioid. Is that correct?
