MS DV vs Sony DV vs Matrox DV
Matt Grunau
Adobe Demigod
Tried using the search option, but being limited to more than 3 letters shut that down.
After recently experimenting with DV codec artifact testing I got to wondering: What DV codec is the best, or does it make a differnce?
I capture in Vegas, but when I open in AE, it says the DV file is a Matrox DV/DVCam, and it used to say Microsoft DV. Vegas just recognizes it as a DV file and leaves it at that. I know I can specify in Vegas to use the Microsoft codec and to ignore 3rd party codecs, so there must be a quality issue or compatability issue of some sort.
Is there a difference? Would I want the Matrox DV over the Microsoft? And how do I tell software to use "X" DV codec. I installed some Matrox codecs a while ago, so I guess it trumped Microsoft's as the default DV codec. Where in Windows does that happen? I certainly never told it to do so. How does one codec become default?
Which would be the best to stick with, or does it matter?
Thanks for any help.
Yes, I know my spelling sucks.
Things change rapidly in the computer industry, but a while back I read a review that put the Vegas codec way out front. (May have been a Charlie White review.) It also held up the best when a test file was re-rendered a bunch of times. The MS codec was not so good. And the Matrox codec can't be read on other machines unless a special file is installed. FWIW.
LHB
David Jimerson said:
Check "ignore third party codecs," and uncheck "use Microsoft DV codec."
Done and done, though I wish there was a way of telling Windows to used Vegas' codec.
THanks guys
The Vegas DV codec is only available from within Vegas and it can't be used as a general Windows DV codec. Vegas writes the DV file with a FourCC code of "dvsd" which identifies it to Windows as a DV file. On your machine, the Matrox DV codec is registered with Windows to handle files with a FourCC code of "dvsd". The Matrox DV codec is actually quite good, but the Sony Vegas is better.
John
