D dolph2000 Well-known member Apr 23, 2006 #1 Hi, If I make a mpeg2 in compressor, I see that it makes QT 640-480 instead of 720-480. Is that normal?
Demistate Veteran May 2, 2006 #2 If you are using the file for regular playback, 640x480 is an acceptable size. However if you want an NTSC DVD capeable file you will need to make it 720x480. (Thats just the DVD standard).
